Restore is used to restore drives, drive partitions and individual files and folders you have protected using
One-Click Backup or
Advanced Backup. When you choose a backup to restore, an on-screen assistant opens to guide you step-by-step through the process. Before beginning the restore process, make sure you have access to your backup files. If the files are saved on discs, gather the discs. If the files are saved on a local
drive, check to make sure they are still there.
