General | |
n Write speed | The speed for recording discs. The available speeds are dependent on the speeds supported by your recorder. |
n Number of copies for this project | The number of copies to burn. |
n Burn Options | The recording method. For example, Write Only, or Read Only. |
n Read Only disc | Select to format the disc as read-only. You will not be able to add data to the disc. |
Advanced | |
n Revert to default settings | Click to reset all options to their original settings. |
n Buffer Underrun Prevention | Select to enable the buffer underrun feature of your recorder. This option is available only if your recorder supports buffer underrun prevention. |
n Raw Mode (Exact Copy) | Select to burn single-session data discs that cannot be burned using normal burn settings. In order use this option, both source and destination driver must support it. |
n Eject After Write | Select to automatically eject disc after the burn process. |
n VariRec laser power settings | Adjust the amount of laser power used to burn a disc. Note: This option only supports blank CD-R media and enforces a recording speed of 4x (704KB/Sec). |
n Write density settings | This option allows you to write more data to a disc than its native capacity would normally allow. Select a value to increase the capacity percentage. Note: This feature only supports blank CD-R media, enforces a recording speed of 4x (704KB/Sec), and makes the disc Read-Only. |
n Perform read speed test when reading from another drive | Select to test the actual read speed of the source disc, and then adjust the write speed or caching options accordingly. |
n Cache to hard disk | Select an option from the drop-down list to indicate when to cache data before burning. |
n Temporary hard disk location | Click to specify the location in which to cache your project. |
n Maximum write buffer allocation | Click to set the maximum amount of memory to allocate for buffering. |
n Enable error logging | Select to create an error log each time you burn a disc. |
n Error log file name | Click and select a location and name for the error log file. |
n Reset “Do not show me again” warnings | Select to reset the “Do not show me again” warnings. Burn setup warnings that you have asked not see again will appear. |
