Set Transition Duration
This dialog box lets you preview transitions, apply a transition, and adjust the duration (display time) of the transition.
To preview a transition:
n Click the arrow in the bottom right corner of the transition thumbnail.
To select a transition and set the duration:
1 In Storyline view, right-click a transition thumbnail and select Set Transition Duration from the shortcut menu.
2 Use Plus (+) or Minus (-) to select the length of time the transition is displayed, or type a new time. For example, you can change the duration from 0.1 seconds to 3.0 seconds.
3 If you want to apply the transition and duration throughout the production, select Apply to all.
Note: In the Timeline view, you can also drag the edge of the transition to adjust the duration.
