Changing the shape and size of objects
You can shape text objects into either curved or straight text. You can also shape graphic objects by resizing them.
To change the shape of a text object:
n Select a text object and choose one of the following buttons to shape it:
To resize an object:
n Select the object and choose one of the following ways to resize it:
n If the object is a graphic or text object, place the cursor over a handle and drag to the desired size.
n If the object is a text object, right-click the text object and choose Size to Text. This resizes the object to be only as large as the text inside the object.
n If the object is a line object, place the cursor over an endpoint and drag to the desired position.
