Styles dialog box—Styles tab
A menu style is a predefined background, button design, font, and object placement for a menu. Music Disc Creator has a library of styles to choose from. You can personalize these styles in the following ways:
n Change the appearance of the text.
n Add a background image and color, and apply a color hue.
n Add or remove Smart Objects that appear on the menu.
You can save the changes that you make, to create a custom menu style that will be available for other Music Disc Creator projects.
You can select different menu styles for each menu in the project, or apply one style to all of the menus.
To select a menu style:
1 Choose a style category from the drop-down list.
2 Click a style to select it.
A preview of the style appears on the right.
3 To change the appearance of the text on the menu, select the text and then click Text Properties.
You can change text properties such as the font, color, size, alignment, or angle. You can also add a shadow or text outline, or background color or image.
4 To add or remove Smart Objects that appear on the menu, click the Smart Objects tab.
For more information, click Help or press F1 in the Smart Objects tab.
5 To save the changes you have made as a custom menu style, click Save as Style. Enter a name for the new style, and then click OK.
6 To apply the new style to your project, click OK.
