Using Beatmatching
Beatmatching automatically adjusts the tempo and synchronizes the beats between tracks to create professional sounding audio CDs. You can create high-energy transitions between tracks and export your entire track list to an audio CD, or as a single file to your portable device.
Note: Beatmatching is not recommended for tracks that have drastically different beats per minute. For example, using beatmatching for two tracks that are 110 BPM and 140BPM, respectively, will result in a rough transition.
To use Beatmatching for an entire track list:
1 Click the Beatmatch button located on the toolbar.
2 Click OK to continue.
Music Disc Creator will then scan your track list, and analyze the BPM. When the scan is complete, the BPM for each track will appear in the BPM column and the track will be reordered based on beats per minute.
3 Click any speaker icon
in the
Transition column to hear how the transition between the selected track and the previous track will sound.
In some cases, it may not be possible for Music Disc Creator to determine the correct location of the beat within a particular song. In this case, you can manually adjust the BPM for a track using the BPM Editor.
To manually beatmatch your track(s):
1 Select the tracks you want to manually beatmatch, then select the Beatmatch option from the drop-down menu in the Transition colum.
Music Disc Creator will then scan all selected tracks, and analyze the BPM. When the scan is complete, the BPM for each selected track will appear in the BPM column.
2 Trim the silence from the beginning and end of your tracks by right-clicking on the tracks and selecting Auto Trim Silence.
3 Sort the tracks according to BPM by clicking the BPM column header.
Note: For audio CD projects that span across multiple discs, tracks will be sorted per disc, not per the entire track list. To sort the entire track list, select MP3/WMA Disc in the Project Type task pane, then click the BPM column header. Then, click the Audio CD project type to return to your current project.
4 Set the transition time by typing the number of seconds to transition from one track to the next.
Tip: As a general rule, it is recommended that you set the Beatmatching transition to 20 seconds or more. If there is a significant difference in BPM between two tracks, the transition will need to be longer.
5 Click any speaker icon
in the
When you are satisfied with the transitions between the tracks in your track list, you are ready to export the track list to CD, or to your connected portable device.
6 Select the desired tracks and click an export option from the Export task pane.
Note: If you click either Send to Portable Device, or Export, an options dialog will appear. Be sure to select Combine all files into one file, including transitions, or your transitions will be lost.
