Removing text from an entire production
If text was added to all or part of the production, you can remove it from the entire production.
To remove a text effect from the entire production:
1 Right-click the Production Editor background and choose Remove > Text Effects.
If there is only one text effect associated with the production, the text object is removed.
If there is more than one text effect associated with the production, the object selector appears. Continue with the following step.
2 Select the text effect you want to remove, and then click OK.
See also:
