creator>PhotoSuite>The PhotoSuite project file format (.DMSP)
DMSP is PhotoSuite’s native file format for edited photos and projects. This format retains layer information and allows you to “undo” changes you have made. With DMSP, both the original settings and the edits (such as transformations or special effects) are stored.
For example, if you crop a photo and save it in DMSP format, you can reverse the edit later, retrieving the deleted portion.
Note: If you save the photo in another format, such as JPEG, BMP, or TIFF, only the portion enclosed within the crop lines is saved. The cropped portion of the photo, the area of the photo lying outside the crop lines, is discarded permanently.
If you share a DMSP file with another user, that user must also have PhotoSuite.
See also:
