Removing or inserting silences
You can easily remove or insert silences to further refine your Sound Editor project.
To remove silences:
2 To preview your selection, use the playback controls (Play, Stop, Previous marker/track, Next marker/track).
3 To remove the silent area, choose Edit > Delete.
To insert silences:
n To insert a silent area into the waveform without overwriting it, complete the following steps:
a Click in the waveform to move the playback cursor to the place where you want to insert the silence.
b Right-click and choose Insert Silence.
c Specify the length of the silent area.
The waveform moves to the right. The silent area appears in the Clip Editor.
n To overwrite a portion of the waveform with a silent area, complete the following steps:
a Click and drag in the waveform to select the section that you want to overwrite with the silent area.
b Right-click the selection and choose Insert Silence.
The selected area of the waveform is replaced with a silence of the same length.
See also:
