Adding a video effect to an individual item
You can add a video effect to an individual item such as a photo, video clip, or color panel.
To add a video effect:
1	In the Production Editor, click the item to which you want to add the video effect.
2	In the Add Content area, click Add Video Effect.
The Add Video Effect dialog box appears.
Tip:  To sort the thumbnails by category, choose a category from the drop-down list.
To see a preview of the video effect, click the Play button in the lower right corner of the thumbnail.
3	Select the video effect, click OK.
4	Select Insert on internal effect track of selected panel and click OK.
The video effect is added to the item, and the item is displayed in Edit Item mode.
5	Click Done to return to Edit Production mode.
Note:  If you have the optional Timeline feature, you can use it to assemble or layer video effects.
See also:
