Creating slide shows with QuickShow
You can combine multiple photos in a slide show. You can add background audio and customize the transitions and screen durations.
Note:  From QuickShow, you can open a slide show for editing in VideoWave.
To create slide shows using QuickShow:
1	Select the photos you want to include in the slide show.
2	On the Task Bar, click QuickShow.
3	Move or click the mouse to display the QuickShow Options Bar.
4	Click QuickShow Settings.
5	Choose QuickShow Settings from the shortcut menu.
6	In the Slide duration box, set the number of seconds each slide will display, or click the check box to fit the slide durations to the background audio.
7	In the drop-down list box, select the transition type.
8	To add zoom and motion effects to the QuickShow, select Apply auto motion effects to images. If you select this option, QuickShow zooms in and out of the photos, and pans across them.
9	To play the sounds associated with the photos, select Play associated sounds.
10	To play a background sound, follow these steps:
a	Select Play background sound.
b	Click Browse, select the audio file you want to use as background, and click Open.
c	Optional: If the playing time for the background sound is longer than the slide show duration, you can fade out the sound at the end of the slide show. Click Fade out background sound if it is too long.
d	Optional: If the playing time for the background sound is shorter than the slide show duration, you can play the background sound repeatedly for the duration of the slide show. Click Loop background sound if it is too short.
See also:
