Adjusting the duration of a transition
You can adjust the transition duration, the length of time it displays.
To set the duration of a transition:
1	Click the transition to select it, and then on the Production Editor toolbar, click Trim.
The Set Transition Duration dialog appears.
2	Use the Plus (+) and Minus (-) buttons to select the length of time the transition is displayed, or type the new time.
3	Optional: If you want to change the transition, click a new transition.
4	Apply the transition as follows:
n	To change the duration of all transitions in the production, click Apply to all.
n	To change the duration of just the selected transition, click OK.
See also:
