Using the Photo Projects Assistant
The Photo Projects Assistant helps you create personalized calendars, greeting cards, and more.
To create a photo project using the Photo Projects Assistant:
1	From Roxio Home, select Create Projects on the Photo projects tab.
The Photo Projects Assistant opens.
2	Select the type of project you want to create.
3	Click Next to continue.
4	Follow the instructions in the Photo Projects Assistant to choose the template or style for your project, add photos and text, and so on.
