Removing wrinkles
To remove wrinkles:
1	If the photo you want to edit is an object in the PhotoSuite project file, select it in the Canvas.
2	In the Fix pane, click Wrinkles.
When you move the cursor over the photo, it becomes a circle with a cross-hair.
3	Use the zoom tools on the Canvas Toolbar to enlarge the photo until you can work easily on the wrinkles.
4	Use the slider to increase or decrease the size of the brush until it is the same width as the wrinkle.
5	Brush over the wrinkled area repeatedly until the wrinkle is removed.
Brushing applies the smoothing effect over the area under the brush. Repeated brushing applies more and more of the effect.
Tip:  To undo a stroke, on the Canvas Toolbar, click Undo.
See also:
