How Roxio Home projects work
When you click on the name of a project from any project list, one of three things will happen:
n	One of the components in your software suite will open. You will be able to use the component to complete your project.
n	A task assistant will open. You will be able to use the task assistant to complete your project.
n	Or, if the project is built into Roxio Home, the tools and instructions you need to complete the project will appear in the project window.
Most the the built-in projects follow a basic three-step process:
1	Select a project from the project list.
2	Follow the instructions in the project window.
3	Click the Go button.
Select one of the links below for more details:
