Adding or removing noise
      The term "noise" in photography refers to unwanted single pixels or groups of pixels that do not belong in the photo. The noise can be caused various factors. Usually, the problems are either introduced electronically by the camera itself or caused by file formats such as JPEG. Noise appears as colored specks within the photo. You can display the noise best by zooming in. For example, you might see specks of red, pink, green, and yellow in a photo of a clear blue sky.
      PaintShop Pro gives you many ways to remove various types of noise, and it even lets you add noise to an otherwise "clean" photo. You can make the following corrections by applying them to a selection or an entire image:
You can reduce the detail in an image and add a grainy texture. By adding a small percentage of noise to an image, you can reduce the appearance of small imperfections and scratches that cannot be removed with other tools.
You can find and eliminate small scratches that are either lighter or darker than the surrounding area.
You can remedy a common problem seen in video capture images in which even- and odd-numbered scan lines are recorded at different rates. The problem is usually noticed if the subject was moving when the image was captured. Note that removing scan lines may make noise more visible.
You can restore a JPEG image to its original appearance. When you save a file to the JPEG format from any software package (such as scanning software), the file information is compressed to create a smaller file. The compression may produce any of the following artifacts: halos or color leakage beyond the edges of objects, checkerboard patterns on smooth backgrounds, or blocky areas.
You can remove undesirable patterns from scanned images. This problem sometimes occurs in scanned photographs printed on textured paper.
You can remove single-pixel specks that are mostly white or black. The brightness of each pixel is analyzed and then compared to the surrounding pixels to determine whether it should be removed.
You can remove noise in a photo without losing details in edges within the photo. For example, you can preserve the edges of facial features while correcting a blotchy complexion.
You can remove small random specks or areas of noise that are distinctly different from the surrounding area. The intensity of each pixel is adjusted to the median intensity of surrounding pixels. (The median intensity is the middle value, not the average,) in the range of values.) To preserve object edges, you can use the Median Filter command. With this command, you can apply more adjustment to a pixel that differs greatly from surrounding pixels than to a pixel that is similar to surrounding pixels. You can specify the number of surrounding pixels to use in the calculation. If you choose a large number of pixels, more noise is removed, so more detail is lost.
You can remove multipixel black or white specks, such as those caused by dust on film or video.
You can remove noise or specks in an image while preserving details in textures. For example, you can preserve textures in clothing while removing noise from another area (such as a person’s face).
In addition, you can use the One Step Noise Removal and the Digital Noise Removal commands. For more information, see To remove digital noise quickly and To use advanced options for removing digital noise.
      To add noise
        Choose
Adjust  Add/Remove Noise
 Add/Remove Noise  Add Noise
 Add Noise.
      The Add Noise dialog box appears.
        Choose a noise pattern option:
Random — creates a granular effect that adds texture
Uniform — changes the color of the noise to resemble the original pixels
Gaussian — makes most of the noise resemble the original pixels more than the
Uniform option
        Type or set a value in the
Noise control to set the percentage of noise to add.
      You can use black-and-white noise pixels by marking the Monochrome check box. To use colored pixels, unmark the check box.
      To remove scratches automatically
        Choose
 Add/Remove Noise  Automatic Small Scratch Removal
 Automatic Small Scratch Removal.
      The Automatic Small Scratch Removal dialog box appears.
        Mark one or both of the following check boxes:
Remove dark scratches — removes scratches that are darker than the background
Remove light scratches — removes scratches that are lighter than the background
        In the
Local Contrast Limits group boxes, type or set values in the
Lower and
Upper controls to set the contrast between a scratch and its background.
      Increase the
Lower control setting to just below where scratches reappear. Decrease the
Upper control setting to just above where the scratches reappear.
        4
        In the
Strength group box, choose an option to set the strength of the scratch removal:
        Note:  Select the lowest setting that removes scratches. Examine all areas of the image to make sure that important details are not lost.
      To limit the correction to a specific area, make a selection. The command works better when applied to a selection than when applied to an entire image.
      To sharpen video capture images
        Choose
 Add/Remove Noise  Deinterlace
 Deinterlace.
      The Deinterlace dialog box appears.
        In either the Before or After pane at the top of the dialog box, drag to pan to the image area where the scan lines are most apparent.
        In the
Scanlines to retain group box, choose an option that specifies whether to retain the odd-numbered or even-numbered scan lines.
      You should apply the Deinterlace command before you resize the image. Resizing adds or removes pixels from the image, which makes it more difficult to identify scan lines. If your image has already been resized, you must return it to the original size as closely as possible so that each scan line is 1 pixel high. Using the zoom control in the dialog box, you can zoom until you can see how many pixels make up one scan line, and then you can resize the image so that each scan line is 1 pixel high. For example, if the enlarged image has scan lines that are 2 pixels high, you would resize it by 50 percent. Note that resizing the image causes it to lose clarity.
      To remove artifacts from JPEG images
        Choose
 Add/Remove Noise  AI Artifact Removal
 AI Artifact Removal.
      It might take a few moments to complete the AI (artificial intelligence) analysis and apply the results, depending on the size and complexity of the image and your computer system.
The green progress bar at the bottom of the application window lets you track the progress of the AI analysis.
      You can apply the AI Artifact Removal command to a file in any format. For example, if you have saved a JPEG file to the PaintShop Pro (.pspimage) format, you can still apply the command.
      Because JPEG compression discards image information, the ability to restore JPEG images is limited.
      To remove moire patterns
        Choose
 Add/Remove Noise  Moire Pattern Removal
 Moire Pattern Removal.
      The Moire Pattern Removal dialog box appears.
Zoom control to magnify the image until you can see the fine patterns clearly.
Fine details control to set the level of pattern removal.
      Change the value one number at a time until the pattern disappears. Higher values may blur the image, so use the lowest value that removes the pattern.
        4
        Use the zoom control in the dialog box to reduce the image magnification until you can see bands or color blotches clearly in the After pane.
        Note:  Although bands or blotches may be visible when the image is displayed at a setting of 100%, they may be easier to see at lower settings.
        5
        Change the value one number at a time in the
Remove bands control until any color bands or blotches become less visible (they may not disappear completely). To avoid desaturation of small objects, use the lowest value possible.
      After you have removed the moire pattern, you may be able to use the Sharpness commands in the Adjust menu to restore detail and remove blurriness without reintroducing the pattern. The Sharpness commands work best when you choose a Fine details setting in the Moire Pattern Removal dialog box that is slightly higher than needed to remove the pattern.
      To remove single-pixel specks
        Select the area in the photo that contains the specks.
        Choose
 Add/Remove Noise  Despeckle
 Despeckle.
      The selection is despeckled.
To remove noise while preserving edges
        Select the area that contains the noise you want to remove.
        Choose
 Add/Remove Noise  Edge Preserving Smooth
 Edge Preserving Smooth.
      The Edge Preserving Smooth dialog box appears.
Amount of smoothing control.
      Choose the smallest amount of smoothing that removes the specks while retaining image detail. You cannot enter a value lower than 1.
      Although you can apply the Edge Preserving Smooth command to the entire image, the command works best when you select the problem area.
      To remove distinct areas of noise
        Choose
 Add/Remove Noise  Median Filter
 Median Filter.
      The Median Filter dialog box appears.
Filter Aperture control to choose the number of surrounding pixels to include in determining the median pixel intensity.
      Values range from 3 to 31 in odd-numbered increments.
        Note:  To preserve image details, choose the smallest filter that removes the noise. For single-pixel colored specks, set the filter to 3.
      Although you can apply the Median Filter command to the entire image, the command works best when you select the problem area.
      To remove multipixel specks
        Select the area that contains the specks.
        Choose
 Add/Remove Noise  Salt and Pepper Filter
 Salt and Pepper Filter.
      The Salt and Pepper Filter dialog box appears.
Speck size control to set the minimum size, in pixels, of the largest speck that can be completely removed. The value is always an odd number.
        4
Sensitivity to specks control to set how different an area must be from its surrounding pixels to be considered a speck.
      Although you can apply the Pepper Filter command to the entire image, the command works best when you select the problem area.
      You can remove all specks that are smaller than the Speck size value by marking the Include all lower speck sizes check box.
      You can intensify the strength of the correction by marking the Aggressive action check box.
      To remove noise while preserving textures
        Choose
Adjust  Add/ Remove Noise
 Add/ Remove Noise  Texture Preserving Smooth
 Texture Preserving Smooth.
      The Texture Preserving Smooth dialog box appears.
Amount of correction control to set a value for the strength of the correction.
      At lower values, a small amount of noise is removed, but textured areas are preserved. At higher values, more noise is removed, but textured areas may not be fully preserved.
      Although you can apply the Texture Preserving Smooth command to the entire image, the command works best when you select the problem area.
