Adjusting brightness, contrast, and clarity
PaintShop Pro lets you adjust the brightness, contrast, and clarity in your photos. Contrast is the difference between the photo’s lightest and darkest pixels. Clarity lets you adjust the level of detail in the image by analyzing contrast within localized areas.
By applying the commands to a selection or an entire image, you can do the following:
manually adjust the brightness and contrast
give your photo a crisp, focused look to make the subject more prominent
adjust the individual brightness values in your image
adjust the brightness and contrast of an image in unison
adjust the highlights, midtones, and shadows to provide smooth tonal transitions
distribute the lightness values of pixels more evenly across the lightness spectrum from black to white
increase the overall contrast when the histogram does not cover the entire lightness spectrum
make adjustments to the brightness, contrast, and gamma in the image
create a purely black-and-white image
Histograms
A histogram lets you display the tonal range of an image and redistribute the balance of highlights, midtones, and shadows. In other words, the histogram can reveal whether your photo is underexposed, overexposed, or exposed properly.
Many digital cameras offer a histogram display on the camera’s LCD, and some cameras even let you adjust the scene’s histogram before you take the photo.
PaintShop Pro has various commands that display the histogram in the dialog box. These commands include Curves, Levels, the advanced mode of Smart Photo Fix, and Histogram Adjustment.
Example of histograms (right) for three different exposures.
Note the following when you look at a histogram:
The left portion of the histogram reveals how much of the photo is black or nearly black.
The right portion of the histogram reveals how much of the photo is white or nearly white.
The graph in the Histogram Adjustment dialog box displays the number of pixels for each value of the selected channel. The vertical axis represents the number of pixels and ranges from zero to the highest number of pixels in the graph. The horizontal axis represents the value of the selected channel, from 0 to 255.
You can display a Histogram for an image at any time by choosing View
Palettes
Histogram.
To change brightness or contrast
Choose
Adjust
Brightness and Contrast
Brightness/Contrast.
The Brightness/Contrast dialog box appears.
Type or set a value in the
Brightness control.
A positive number lightens the photo; a negative number darkens the photo. A value of zero preserves the original setting.
Contrast control.
A positive number increases contrast; a negative number decreases contrast. A value of zero preserves the original setting.
You can use the zoom control in the dialog box to set your view of the image in the Before and After panes.
To brighten dark areas and adjust clarity
Choose
Adjust
Fill Light/Clarity.
The Fill Light/Clarity dialog box appears.
Fill Light control.
Higher values lighten the darkest areas of the photo; a value of zero preserves the original setting.
Clarity control.
A positive number increases detail; a negative number decreases detail and focus. A value of zero preserves the original setting.
To enhance depth and clarity
Choose
Adjust
Local Tone Mapping.
The Local Tone Mapping dialog box appears.
Strength control.
Use the smallest value that produces a satisfying result. Values that are too high cause unwanted artifacts to appear in the photo.
To change color channel brightness
Choose
Adjust
Curves.
The Curves dialog box appears.
In the
Channel drop-list, select one of the following color channel options:
RGB — lets you edit the red, green, and blue channels in a combined histogram
Red — lets you edit the red channel only
Green — lets you edit the green channel only
Blue — lets you edit the blue channel only
Drag points on the graph to adjust the relationship between the input levels (the brightness of the original pixels) and the output levels (the brightness of the corrected pixels).
As you drag a curve point, the point’s original and modified values for pixel lightness are displayed in the upper-left corner of the histogram graph. The original or input value appears on the left), and the modified or output value appears on the right.
Click where you want to add the point to the curve.
Note: Adding more points to the curve lets you adjust its shape more precisely.
Drag the point to the left or right off the graph.
Move the active curve point more precisely
Press or hold down the Arrow keys.
Automatically adjust the photo’s contrast
Click the Contrast button in the Auto group box.
Note: You can use this button when you’re satisfied with the photo’s colors but want to improve the contrast.
Automatically adjust the photo’s white balance
Click the Color button in the Auto group box.
Note: You can use this button to find a black point and a white point in the photo automatically.
Automatically adjust both the contrast and the color
Click the Levels button in the Auto group box.
Set your own black, gray, or white point
Click the black, gray, or white dropper in the Colors group box to activate the dropper color. Then, move the cursor into the Before pane and click what you know to be a black, gray, or white point.
The After pane (and the image window if the Preview on Image check box is marked) is updated.
Automatically determine the appropriate black, gray, or white point
Hold down Alt, and position the cursor in the Before pane (or in the image window). As you move the cursor over dark, medium, and light areas, the appropriate color dropper becomes active. Click to set that point.
Specify histogram clipping limits for the Auto Contrast, Color, and Levels buttons
Click the Options button. In the Auto Color Options dialog box, set percentage values for the Lower Limit and Upper Limit controls, and for the Strength control.
Note: For the Lower Limit and Upper Limit controls, higher values result in stronger automatic settings, and lower values result in weaker automatic settings. Lower Strength values result in less clipping.
Reset all modified values to the original values
Click the Reset button located near the Colors droppers.
You can also click the Reset to Default button located next to the Save Preset button.
To adjust brightness and contrast simultaneously
Choose
Adjust
Gamma Correction.
In the Gamma Correction dialog box, the graph shows the gamma curves for the three colors. If the three colors have the same gamma value, there is one white line representing the three colors. If the gammas are different values, there is a line for each color.
The left side of the graph represents the shadows of the image; the right side represents the highlights.
Do one of the following:
To adjust the brightness and contrast in unison, mark the
Link check box.
To change the color balance of the image rather than the brightness and contrast, unmark the
Link check box.
Adjust the
Red,
Green, and
Blue values, drag the sliders or type new numbers in the edit boxes.
A value of 1 indicates the original gamma. If colors are linked, increasing the value lightens the image and decreasing the value darkens the image. If colors are not linked, increasing or decreasing a individual color value increases or decreases the amount of that color in the image.
The Gamma Correction command can result in an image looking somewhat flat. You may want to increase the contrast after correcting the gamma. For more information, see To change brightness or contrast.
To apply this command to a selection, the image must be a 16 million (24-bit) color image (otherwise the command is applied to the entire image). To increase the color depth of an image, see To increase the color depth of an image.
To adjust a photo’s highlights, midtones, and shadows
Choose
Adjust
Highlight/Midtone/Shadow.
The Highlight/Midtone/Shadow dialog box appears.
Choose one of the following options:
Absolute adjustment method — sets the absolute positions of the 25% histogram point (Shadows), the 50% histogram point (Midtones) and the 75% histogram point (Highlights). Typical values are about 35 for Shadow, 50 for Midtone, and 65 for Highlight, but they vary, depending on the photo. Increasing the value lightens the region, and decreasing the value darkens the region.
Relative adjustment method — adjusts the lightness levels relative to their original states. Positive values lighten the region, and negative values darken it.
Type or set values in the
Shadow,
Midtone, and
Highlight controls.
To correct exposure by using the histogram
Choose
Adjust
The Histogram Adjustment dialog box appears.
In the
Edit group box, choose one of the following options:
Luminance — lets you set the lightness values of the image to correct contrast
Colors — lets you choose a color channel to edit
If you choose the
Colors option, you must choose a color from the drop-list.
In the
Load Preset drop-list, choose
Default.
The default values represent no adjustment to the image.
On the left side of the histogram, look for a gap between the left edge and the point where the graph starts to rise. A gap shows that the darkest pixels in the image are not completely black. Drag the
Low slider (the black triangle) to the point where the graph rises. The
Low control displays the low position (from 0 to 254). The bottom control displays the percentage of pixels that are between zero and the low value; contrast for these pixels will be lost. As a general rule, keep the
Low value lower than 0.1%.
5
Adjust the
High slider.
On the right side of the histogram, look for a gap between the right edge of the window and the point where the graph decreases to zero pixels. If there is a gap, drag the
High slider (the white triangle) to that point on the graph. This action changes the lightest pixels in the image to white. As a general rule, keep the
High value lower than 0.1%.
6
Adjust the
Gamma slider.
If the overall image is too dark or too light, adjust the gamma, which is a standard measure of change in an image’s contrast. To lighten the image, increase the gamma by dragging the
Gamma slider (the gray triangle) to the right. To darken the image, decrease the gamma by dragging the
Gamma slider to the left.
7
Adjust the
Midtones slider.
Note: If the graph has peaks on the left and right sides and contains low points in the center, the midtones need to be compressed. Shadows and highlights must be expanded to reveal the information they contain. Photography subjects that are too close to the camera appear brightly illuminated against a dark background. To compress the midtones, drag the
Midtones slider up.
If the graph peaks in the center and has a low number of pixels at the left and right sides, expand the midtones by dragging the
Midtones slider down.
You can create artistic effects by using the Output Max and Output Min controls on the left side of the histogram. The Max slider is the white circle within a gray square; the Min slider is the black circle within a gray square. To darken the image’s lightest pixels, drag the Max slider down. To lighten the image’s darkest pixels, drag the Min slider up. Even though you are dragging sliders along the vertical axis, the Max and Min values (from 0 to 255) affect the horizontal axis. All pixels outside the range are converted so that they fall within the range. You can choose another color component from the Edit drop-list and make similar adjustments.
To distribute lightness across a photo
Choose
Adjust
Histogram Equalize.
To increase contrast by stretching the histogram
Choose
Adjust
Histogram Stretch.
The Histogram Stretch command pulls the darkest pixel down to black and the lightest pixel up to white. This command does not affect images that already span from pure black to pure white. If the original image has pixels that are very close to black and white, using this command will have a very small effect. If the original image is very flat (nothing close to black or white), using this command will have a strong effect.
To adjust brightness, contrast, and gamma simultaneously
Choose
Adjust
Levels.
The Levels dialog box appears.
In the
Levels group box, choose the color channel to adjust from the
Channel drop-list:
Adjust the black, gray, or white diamond sliders, or set values in the controls beneath them.
To darken the darkest pixels in the photo, drag the black diamond slider to the right (or set a value in the numeric control).
To adjust the photo’s midtones, drag the gray (middle) diamond to the left or right (or set a value in the numeric control).
To lighten the lightest pixels in the photo, drag the white diamond slider to the left (or set a value in the numeric control).
Note: To see which pixels are being clipped as you drag either the black or white diamond slider, hold down
Ctrl as you drag. The After pane displays the clipped colors.
Click the black, gray, or white dropper in the Colors group box to activate that dropper color. Then, move the cursor into the Before pane (or into the image window), and click what you know to be a black, gray, or white point.
Click the Options button. In the Auto Color Options dialog box, set percentage values for the Lower Limit and Upper Limit controls and for the Strength control.
Changes you make in the Auto Color Options dialog box are applied when you use the Contrast, Curves, and Levels buttons in the Auto group box of the Curves dialog box.
You can use the Levels command to spread out the histogram for a photo taken with an improper exposure. You may find it helpful to use this command before using the Curves command.
To convert a photo’s pixels to black and white
Choose
Adjust
Threshold.
The Threshold dialog box appears.
Type or set a value for pixel lightness in the
Threshold control to specify which pixels to change to white (those above the threshold) and which pixels to change to black (those below the threshold).
Values range from 1 to 255. Lower values produce more white pixels; higher values produce more black pixels.
