Customizing toolbars
When you display the Customize dialog box, the entire PaintShop Pro workspace transforms into customize mode. You can click and drag almost any menu command or tool to any other menu or toolbar. You can add or delete commands from the menus on the Menu bar.
To move a toolbar button
With the Customize dialog box displayed, drag the item to another toolbar.
To add a command button to a toolbar
Choose
View
Customize.
The Customize dialog box appears.
Click the
Commands tab.
From the Categories list, select a category.
Note: PaintShop Pro groups related commands into categories. For example, click the
File category to display all File menu commands. To list all PaintShop Pro commands at once, choose
All Commands.
4
From the
Commands list, drag a command to a toolbar.
To remove a command button from a toolbar
With the Customize dialog box displayed, drag the item to an empty workspace area or an empty area outside a toolbar.
Release the mouse button when you see the cursor change to this shape:
To reset all toolbars
Choose
View
Customize.
Click the
Toolbars tab.
All toolbars revert to the default settings.
You can reset a specific toolbar to its default settings by choosing it from the Toolbars list and clicking Reset.
You can also open the Customize dialog box by right-clicking the Menu bar, Tool palette, or Tool Options palette, and choosing Customize.
You can rearrange a button in relation to the separator by dragging the button to the desired location.
