Editing and saving layouts
PaintShop Pro includes many templates with different layouts that you can use to print your images. The layouts you create can be saved as templates.
You can arrange images in a layout automatically or manually. Before you arrange images automatically, you must choose whether to include borders. If you do not use borders, PaintShop Pro may arrange the images with touching edges. You must also choose whether to size the images to fit the layout. If you do not choose this option, PaintShop Pro keeps them the same size or, if necessary, makes them smaller to fit the layout. PaintShop Pro divides the page into sections of equal size and places each image in a section. Only images on the page or in the window are used.
Horizontal and vertical gridlines help you position items evenly on a page. You can display or hide grids and set preferences for grid spacing and appearance. When you display grids, they appear in any image window that is open.
You can snap images to the nearest gridline on the layout.
To resize an image in print layout
Click the
Resize button
on the toolbar.
Choose one of the following options:
Percent of original — resizes an image by a percentage you specify in the
Width or
Height boxes
Actual / Print size — resizes an image by the dimensions you specify in the
Width or
Height boxes without changing its aspect ratio
Resizing an image for printing can result in poor image quality. When you enlarge an image, it loses detail and sharpness. As a general rule, it is best to avoid enlarging or reducing an image by more than 25 percent.
You can also resize an image manually by dragging a corner handle.
To use borders in a print layout
Choose
View
Options.
Mark the
Use Borders check box, and type or set values in the
Horizontal border size and
Vertical border size controls.
The default border width is 0.5 inches (1.27 centimeters).
If you want to resize images to fit in their cells, mark the Stretch to fit check box.
As you decide where to move images, you can place them temporarily in the area around the page.
You can also arrange images manually by dragging the image to a new position on the page.
To display the grid
Choose
View
Show Grid.
To snap images to the layout grid
Choose
View
Snap to Grid.
To change layout grid settings
Choose
View
Options.
The Print Layout Options dialog box appears.
In the
Grid Settings group box, mark any of the following check boxes:
Show Grid — displays the grid
Snap-to-Grid — snaps images to the gridlines when you position them
Note: If you mark the
Show Grid check box, you can mark the
Dot Grid check box to use a dotted-line grid instead of a solid-line grid.
Click the Grid color area, and choose a color from the color palette.
Change the horizontal and vertical spacing
Set values in the Horizontal Spacing and Vertical Spacing boxes.
To save a custom layout as a template
Click the
Save Template button
The Save dialog box appears.
Enter a name for the new template in the
Name field.
If you want to save the image links with the template, mark the
Save with Images check box.
To rotate an image in a layout
Choose
Image, and then choose one of the following commands:
To position an image in a layout
Drag the image to a new position on the page.
