Exporting and importing gradients
After creating a new gradient, you may want to export it to use in another program. The default gradients are stored in the GRD file format, which is commonly used in other applications.
You can also import gradients in the GRD file format.
To export a gradient
On the Gradient page, select the gradient that you want to export.
Click the
More Options button
, and choose
Export.
The Export dialog box appears.
Select the folder in which you want to save the gradient.
Gradients folder within the PaintShop Pro program folder.
4
In the
File name field, type a name for the new gradient.
To import a GRD gradient
On the Gradient page, click the
More Options button
, and choose
Import.
The Import dialog box appears.
Select the folder that contains the gradient you want to import.
All GRD files are listed in the folder.
Select the gradient’s filename, and click
Open.
