Grouping and ungrouping vector objects
You can group several objects or groups of objects to move, resize, reshape, and change their lines and materials.
When you group objects on different layers, PaintShop Pro automatically moves them to the layer of the first object you select. Each group is labeled on the Layers palette and the objects in the group are shown as components.
To group or ungroup vector objects
Back to Top
Edit tab
To
Do the following
Group objects
Using the Pick tool , select the objects you want to group. On the Tool Options palette, click the Group button .
Ungroup objects
Using the Pick tool , select the group. On the Tool Options palette, click the Ungroup button .
To group objects by using the Layers palette
Back to Top
Edit tab
1 On the Layers palette, click the first object you want to group.
2 Hold down Shift, and click each object you want to add to the group.
3 Right-click, and choose Group.
If you group objects from several layers, PaintShop Pro moves them to the layer of the first object you selected.
Click the plus sign (+) next to the group name to show the group’s components.
To remove an object from a group
Back to Top
Edit tab
• On the Layers palette, drag the object to another group or layer.
