Importing and sharing brush tips
You can import custom brushes or create your own. For information about creating custom brushes, see Creating brush tips and presets.
After you create a custom brush tip, you can share it with others by sending them the brush file. If the brush uses a custom shape, you must share both the brush file and the custom shape file for that brush.
To import a custom brush
Choose
File
Import
Custom Brush.
The Import Custom Brush dialog box appears.
In the Open dialog box, navigate to the brush file that you want to import, and click
Open.
4
In the Import Custom Brush dialog box, select the custom brushes that you want to import, and click
Add.
If you want to import multiple brushes, click
Add All.
5
Click
OK to import the custom brushes.
To share brush tips
Navigate to ...Documents\Corel PaintShop Pro\2023\Brushes.
Navigate to the folder in which you saved your custom brushes if it is different from the default Brushes folder.
Share the brush files (those with
.PspBrush or
.PspScript extensions) — for example, by attaching them to an e-mail message.
The recipient should save the brush files to ...Documents\Corel PaintShop Pro\2023\Brushes, or to the folder that contains custom brushes.
If you are sharing brushes created from selections, you must share both the PspBrush file and the associated PspScript file.
