Modifying the edges of selections
You can modify the edges of a selection by smoothing its boundary or by adding a border.
To smooth the boundary of a selection
Choose
Selections
Modify
Smooth.
The Smooth Selection dialog box appears.
Mark or unmark the following options:
Anti-alias — smooths the edges of the selection
Preserve Corners — preserves the shape of the corners. Unmark this check box if you want to smooth the corners.
Specify values for one or both of the following controls:
Smoothing amount — specifies the amount of smoothing to apply around the selection
Corner scale — specifies the amount of smoothing to apply around the corners of the selection. This control is not available when the
Preserve Corners check box is not marked.
You can click the Toggle Selection button
in the Smooth Selection dialog box to toggle between a preview of the selection and a preview of the selection and the rest of the image.
To add a border to a selection
Choose
Selections
Modify
Select Selection Borders.
The Select Selection Borders dialog box appears.
Mark one of the following options to set the position of the feathering:
Type a value in the
Border width box.
If you want to smooth the edges of the selection border, mark the
Anti-alias check box.
