You can move, clip, or rotate a selection. If you want to change the selection area, you can also move the selection marquee.
When you move a selection, you can leave the space empty or you can move a copy of the selection and leave the original unchanged. When you move a selection, it becomes a floating selection. When you perform a new action, PaintShop Pro automatically promotes the floating selection to a new layer.
You can also float a selection, which creates a copy of the selection that you can move or modify without changing the original image. A floating selection temporarily rests above the image or layer on the Layers palette, and an icon indicates that the layer contains a floating selection. After you edit the floating selection, you can defloat it.
You can also move a selection to a separate layer. When you do this, the original selection contents are unchanged, and a copy of the selection becomes the new layer. You can edit this new layer without changing the original image.
After making a selection, you can move the selection anywhere on the image, or off the canvas. If you expand the image window to show the off-canvas gray area, you can see the selection you moved. You can also clip a selection to remove the portion that is not within the image borders.
      You can also move the selection marquee by right-clicking and dragging with the Move tool .
      To place a selection as a layer within another image, copy the selection, open the other image, and choose Edit  Paste As New Layer.
 Paste As New Layer.
      When you rotate a selection, the selection becomes a floating selection, and the original image remains unchanged.
You can also rotate a selection interactively by using the Pick tool . Before the rotation is applied, the selection is promoted to a layer.
