Removing red-eye
      Red-eye in photos is a common problem. When light from the camera’s flash reflects off the retina of a photo subject, a red-eye effect is captured in the photo. PaintShop Pro has two methods of removing red‑eye from a color photo.
      The fastest method of removal is to use the Red Eye tool. A more powerful method is to use the advanced Red Eye Removal command, which lets you change the eye color.
      The Red Eye tool replaces the red color in the subject’s pupil with a dark gray color, restoring a natural look.
      To remove red-eye quickly
        On the Tools toolbar, choose the
Red Eye tool
        On the Tool Options palette, adjust the
Size of Red-Eye control so that the pointer is about twice the size of the red area needing correction.
        Position the pointer directly over the eye, and click.
      You can zoom in on the photo, if necessary, for better control of the Red Eye tool.
      You can size the pointer interactively by holding down Alt while dragging the Red Eye tool over the eye area.
      To use advanced options for red-eye removal
        Choose
Adjust  Red Eye Removal
 Red Eye Removal.
        In the After preview area, drag to center the red eyes of the subject. If necessary, use the
Zoom control to see the eyes in more detail.
        Choose a color variation option from the
Hue and
Color drop-lists.
        Note:  The
Hue drop-list is available only for the
Auto Human Eye method.
        4
        From the
Method drop-list, choose one of the following correction methods:
Auto Human Eye — automatically selects the correction area and chooses settings appropriate for a human eye
Auto Animal Eye — automatically selects the correction area and chooses settings appropriate for an animal eye. This method lets you rotate the selection.
Freehand Pupil Outline — lets you use the
Freehand Selection tool to select the correction area for human or animal eyes
Point-to-Point Pupil Outline — lets you use the
Point-to-Point Selection tool to select the correction area for human or animal eyes
When more careful correction is needed, such as for a partially obscured pupil, it is best to use the
Freehand Pupil Outline method or the
Point-to-Point Pupil Outline method.
        5
        In the Before preview area, perform one of the following tasks:
For the
Auto Human Eye or
Auto Animal Eye method, click inside the red area of the eye to select the eye automatically, or drag from the center of the eye to the outside edge of the red area.
For the
Freehand Pupil Outline method, drag around the edge of the red area of the pupil until you reach the beginning point of the selection.
For the
Point-to-Point Pupil Outline method, click around the edge of the red area of the pupil, and double-click when you reach the beginning point. You can reverse a click by right-clicking.
After you select the eye, a circle appears around the selected area, and a control box for making adjustments encloses the circle. The After preview area displays the corrected eye.
        Note:  If you choose the
Point-to-Point Pupil Outline method, confine the selection area to the pupil of the eye (the small dark circle at the eye’s center). These methods are designed to correct the pupil area, where red-eye occurs, without changing the surrounding iris.
        6
        Set the following controls to fine-tune the red-eye correction:
Pupil lightness — specifies the amount of lightness in the pupil so that the corrected eye matches the natural eye color
Iris size — specifies the size of the iris. Increasing the iris size decreases the pupil size.
Glint lightness — specifies the lightness of the glint. Lower values darken the glint; higher values lighten it.
Glint size — specifies the size of the glint
Feather — adjusts the edges of the corrected eye so that they appear to blend into the surrounding image areas or appear more defined. Lower values make the edges more defined; higher values blend the edges into the surrounding image areas.
Blur — blends the eye with surrounding pixels when the photo has a grainy appearance. You can increase the setting one unit at a time until the eye blends naturally with the rest of the image.
          | Move the glint to the center of the pupil | Mark the Center glint  check box. |
          | Rotate a selection for an animal eye | Drag the center rotation handle. |
          |  | Drag the side handles of the selection. |
      The Refine slider helps you correct red-eye when the eye is partially obscured in the original photo. For example, if the eyelid covers part of the eye in the original photo, it should also cover that part of the eye in the corrected photo. Dragging the slider to the left reduces the correction and minimizes its overlap with the surrounding skin.
