The Autosave Settings window lets you specify Auto-Recover and Autosave options.
Edit tab: You can enable Auto-Recover to save temporary copies of all open files at specified intervals. If the application closes unexpectedly, the copies will be recovered the next time you open the application.
Adjust tab: If you have enabled the Adjust tab, PaintShop Pro lets you automatically save your work as you move between tasks. For example, if you make some edits from the Adjust tab, and switch to another photo or tab, your changes will be applied automatically.
It is recommended that you enable Auto-Preserve if you enable Autosave. For more information, see Setting Auto-Preserve preferences.
To find out where PaintShop Pro saves the Auto-Recover files, choose File
Preferences
File Locations and select the Undo/Temporary Files folder from the File Type list.
