Using and creating presets
Presets are scripts that define the behavior, properties, or settings of a dialog box or tool. Many dialog boxes and tools come with predefined, ready–to–use presets; however, you can also design and save your own presets. This is useful if you frequently use the same settings in a dialog box or with a tool. By using presets, you can save the settings and they'll appear in the Presets drop-list associated with that dialog box or tool.
To choose a preset
In the
Presets drop-list, select the desired preset from the list.
On the left is the Pan tool’s Presets drop-list button in the Tool Options palette, and on the right the Presets drop-list in a dialog box.
To reset values to default settings
In the
Presets drop-list, click the
Reset to default button
To reset a dialog box to the settings that displayed when you opened the dialog box, hold down Shift and click the Reset to default button.
To save settings as a preset
Modify the settings in the dialog box or the Tool Options palette.
Click the
Save preset button
to display the Save Preset dialog box.
Type a name for the preset.
Note: You cannot use "Default" or "Last Used" as the name for a preset.
If you want to enter additional preset information, click
Options, and type text in the
Author,
Copyright, and
Description fields.
The Preset includes group box shows the data saved with a preset.
To edit a preset
Click the
Save Preset button
Type the same preset name in the preset name box.
If you want to omit any data from the
Preset includes group box, click the
Include/Exclude button
associated with the data.
A white "X" appears over the button associated with the item.
To delete a preset
In the
Resource Manager button
In the Resource Manager dialog box, select the preset you want to delete.
