Working with custom color palettes and swatches
When you save swatches, you save them to a custom palette. You can create multiple palettes. For example, you can save all the colors and materials for a particular project on a custom palette. You can delete palettes that you no longer need.
You can also load a custom color palette created in PaintShop Pro. For example, a business can share corporate color by using a palette with custom swatches, artists drawing the same cartoon characters can share palettes, or graphic designers can take inspiration from one of the pre-loaded palettes.
Swatches
Swatches are styles or materials created from colors, gradients, patterns, or textures that you can save to use again. Swatches offer a way to save your favorite colors, styles, and materials so that you can access them quickly when you are working on projects.
You can select, create, edit, delete, and rename swatches. You can also change the way swatches are displayed.
Palettes are saved as folders, with the collection of swatch files (.pspscript) within the folder. By default, they are saved in the following location: [C]:\Users\[user name]\Documents\Corel PaintShop Pro\2023\Swatches\...
To choose a color palette
On the Materials palette, click the
Swatches tab
Click the Palette selection menu and choose a palette from the drop-list.
The swatches for the selected palette display on the Materials palette.
To create a palette
Swatches tab
Click the
More Options button
, and choose
New Palette.
Type a name for your palette and click
OK.
The palette is added to the drop-list above the swatches. You can now add swatches to the palette. By default, the palette is saved in [C]:\Users\[user name]\Documents\Corel PaintShop Pro\2023\Swatches\...
To delete a palette
Swatches tab
From the palette drop-list, choose the palette you want to delete.
Click the
More Options button
, and choose
Delete Palette.
To import a palette of swatches
Do one of the following:
Copy the palette folder (contains the .pspscript files for each swatch in the palette) to the default user location: [C]:\Users\[user name]\Documents\Corel PaintShop Pro\2023\Swatches
Copy the palette folder ((contains the .pspscript files for each swatch in the palette) to the location of your choice and choose
File
Preferences
File Locations, click
Swatches in the
File types list, and click
Add to navigate to the location where you stored the palette folder.
To create a swatch
Swatches tab
Click the
Add to Palette button
In the
Add to Palette dialog box, choose a palette and click
OK, or click
New to create a palette.
4
In the
New Swatch dialog box, type a name for your swatch.
This name appears as a tooltip when you hold the pointer over the swatch on the Materials palette.
The swatch appears on the Materials palette.
You can also click the More Options button
on the Materials palette, and choose New Swatch.
To select a swatch
Swatches tab
To select a swatch as the foreground material, click the swatch.
To select a swatch as the background material, right-click the swatch.
To edit a swatch
Swatches tab
Double-click the swatch you want to edit.
The Material Properties dialog box appears.
Edit the style (color, gradient, or pattern) or the texture for the material.
You can also click the swatch, click the More Options button
, and then choose Edit Swatch.
To delete a swatch from a palette
Swatches tab
Click the swatch you want to delete.
Click the
Remove from Palette button
, and choose Delete Swatch.
To rename a swatch
Swatches tab
Click the swatch you want to rename.
Click the
More Options button
, and choose
Rename Swatch.
To change how swatches are displayed
Swatches tab
, and perform a task from the following table.
Select which swatch types are displayed
Click the More Options button  , choose View, and then choose the swatch type to display.
Change how swatches are sorted
Click the More Options button  , choose Sort By, and then choose Style or Name. By default, the swatches are sorted by style.
Change swatch thumbnail sizes
Click the More Options button  , and choose Small Thumbnails, Medium Thumbnails, or Large Thumbnails. Medium thumbnails are displayed by default.
