Working with thumbnails in the Manage tab
The Manage tab makes it easy for you to preview and organize photos by using thumbnails.
For a larger view of photos, use Preview mode, zoom in and out on thumbnails, or use Quick Review to view photos in full-screen mode. You can sort thumbnails by criteria such as name, rating, or date. You can also rotate photos by using thumbnails, or delete and rename the files.
For multi-image shooting, you can use Auto Group and RAW/JPG Pairs to group and view thumbnails according to bracketing settings or JPEG+RAW file pairs.
Thumbnails let you edit multiple photos by using Capture editing and Apply editing. For more information, see Capturing and applying edits to multiple photos.
In addition, you can select one or more RAW file thumbnails to convert the files to another format. For more information, see Converting RAW photos to another file format.
To preview an image in Manage
In the Organizer palette, click a thumbnail.
If you are not in Preview mode, click the
Preview mode button
in the upper-right corner of the application window.
The photo is displayed in the Preview area.
Display the previous or the next image in the Preview area by using the keyboard
Press the Left arrow or the Right arrow keys.
Preview an image in full-screen mode
Click View Full Screen Preview, or double-click a thumbnail to open Quick Review. For more information, see Using Quick Review to review photos.
To zoom in or out on thumbnails
If the Manage tab is not in Thumbnail mode, click the
Thumbnail mode button
in the upper-right corner of the Manage tab.
On the Organizer toolbar, move the
Zoom slider to the left to zoom out, or to the right to zoom in.
The Zoom slider is not available when the Manage tab is in Preview mode.
To sort thumbnails
On the Organizer toolbar, click the
Sort by drop-list.
Choose a sorting option.
Choose one of the following options:
Date Created - Newest — sorts thumbnails, from newest to oldest, by the date on which the photo was taken
Date Created - Oldest — sorts thumbnails, from oldest to newest, by the date on which the photo was taken
Date Modified — sorts thumbnails by the date on which the image was last modified
Folder —
sorts thumbnails alphabetically by folder name
Filename — sorts thumbnails alphabetically by filename (image name)
Rating — sorts thumbnails by image rating
File Format —
sorts thumbnails alphabetically by filename extension (for example, .psp image, .jpg, or .tif)
File Size — sorts thumbnails by the file size (in kilobytes) from smallest to largest
Place — sorts thumbnails by the location that is associated with the photo
To group thumbnails according to shooting time
Auto Group and set a time interval.
Photos that have been captured within the time interval are displayed as sets (dividers appear between sets).
To control how RAW and JPEG pairs are displayed
RAW/JPG Pairs button, and choose one of the following options:
ON - Show JPG Versions — shows the JPEG versions as thumbnails and hides the RAW versions
ON - Show RAW Versions — shows the RAW versions as thumbnails and hides the JPEG versions
OFF — shows thumbnails for both the RAW and JPEG versions of the files.
If you delete a thumbnail when the RAW/JPG Pairs option is turned on, both versions of the files are sent to the Recycle Bin.
To select more than one thumbnail
Do one of the following:
To select adjacent thumbnails, hold down
Shift, and click the first and the last thumbnail in the sequence of thumbnails.
To select nonadjacent thumbnails, hold down
Ctrl, and click the thumbnails.
To rotate one or more images in the Organizer palette
Select one or more thumbnails.
On the Organizer toolbar, click one of the following buttons:
Rotate Right
— rotates thumbnails 90 degrees clockwise
Rotate Left
— rotates thumbnails 90 degrees counterclockwise
You can also right-click a thumbnail and choose Rotate Right or Rotate Left from the context menu.
To delete one or more photos in Manage
Select one or more thumbnails, and press
Delete.
The Delete File dialog box or Delete Multiple Items dialog box appears.
Click
Yes to send the images to the Recycle Bin.
You can also delete photos by selecting thumbnails, right-clicking a selected thumbnail, and clicking Delete in the context menu.
To rename a file in the Manage tab
Right-click the thumbnail of the file that you want to rename and choose
Rename.
In the Rename File dialog box, type the new filename, and click
OK.
To open one or more images for advanced editing
Select one or more thumbnails, and click the
Edit tab.
The images open in the Edit tab.
You can also start the Edit tab by right-clicking one or more selected thumbnails and clicking Edit Photo in the context menu.
