Setting workspace tab preferences
You can hide or show optional tabs for the current workspace. You can also choose which tab is open by default when you launch the application. For example, you can choose to display the content on Welcome tab or the Edit tab when the application opens.
To hide or show tabs and set the default tab
Back to Top
Edit tab
Manage tab
1 Choose File Preferences General Program Preferences.
The Preferences dialog box appears.
2 Click Tabs in the list of categories on the left.
3 In the Visible Tabs area, mark the check boxes for the optional tabs you want to show.
4 Choose one of the following default tab options, and click OK.
• Set Welcome as default — displays the Welcome tab content when you launch the program
• Set Manage as default — displays the Manage tab content when you launch the program
• Set Adjust as default— displays the Adjust tab content when you launch the program
• Set Edit as default— displays the Edit tab content when you launch the program
• Keep Last View — displays the tab you used before you closed the program in your last PaintShop Pro session
