When you open an image in PaintShop Pro, it appears in an image window. The title bar of the image window displays the image filename and the level of magnification applied to the image. An asterisk after the filename indicates that the image has been modified and that the changes have not been saved.
You can view basic image information, such as the height and width of an image (in pixels) and its color depth. You can also view detailed information for the image, such as its resolution, color depth, layers and alpha channels, and EXIF data. You can also view the number of unique colors in an image.
You can also view and edit image information in the Info palette that you can access from the Manage tab. For more information, see Displaying and editing photo information.
The EXIF Information tab of the Image Information dialog box lets you view EXIF data for digital camera photos. When you take a photo with a digital camera, the camera attaches information to the image, such as the date and time that it was captured, the exposure, and the flash settings. When you load a photo from a digital camera into PaintShop Pro, you can view this extra information.
You can expand the workspace to preview an image without the menus, toolbars, or palettes visible.
The Status bar, which is located at the bottom of the application window, displays the cursor position, height and width in pixels, and color depth for the current image.
When the Organizer palette is open, you can use Quick Preview to quickly view larger versions of the thumbnails.
If you have two monitors, you can use Dual Monitor to open the Manage tab on one monitor and the Edit tab on a second monitor.
You can also add IPTC data to the image information by using the Advanced Creator Information dialog box. This can be useful for photojournalists, for example, who may need to record IPTC data about when and where a photo was shot, and how urgently the photo needs to be reviewed. To access this dialog box, click the Creator Information tab, and then click Advanced.
To return to the PaintShop Pro workspace, press any key.
