Adding and closing contours
You can add new contours to any existing object. The new contour will have the same properties, including color, material, line style, and so on, as the selected object. You can also duplicate contours.
To add a contour to an object
On the Tools toolbar, click the
Pen tool
In the Tool Options palette, click the
Edit Mode button
4
Click one of the following buttons:
Draw Lines and Polylines
Draw Point-to-point Bézier Curves
Draw Freehand
5
Drag on the object to create the contour.
To close a contour
On the Tools toolbar, select the
Pen tool
On the Tool Options palette, click the
Edit Mode button
4
Click the
Close selected open contours button
When you close a contour, PaintShop Pro draws a segment from the contour’s start node to its end node.
