Editing contours and paths
You can edit the contours and paths of vector objects. You can join contours by connecting their end points. You can also reverse the direction of paths and contours. The direction of a contour flows from the start node to the end node. When you place the cursor over the start node, a "START" message appears next to the cursor. When you place the cursor over the end node, an "END" message appears. If the object has a closed path, a "CLOSE" message appears.
You can duplicate contours.
For more information about the different types of nodes, see Modifying lines and curves.
To join two contours
Back to Top
Edit tab
1 On the Tools toolbar, select the Pen tool .
2 On the Tool Options palette, click the Edit Mode button .
3 Select one of the contours you want to join.
All of the nodes in the object are displayed.
4 Select the start or end node of the first contour you want to join.
Note: You can only join contours in the same object.
5 Hold down Shift, and select the start or end node of the second contour.
6 Right-click, and choose Edit Join.
You can also join contours manually. Drag a node on the first contour over the second contour’s start or end node. When the cursor displays "JOIN," release the mouse button.
To break a contour at a node
Back to Top
Edit tab
3 Select the node where you want to break the contour.
4 Right-click the node, and choose Edit Break.
The path or contour breaks and a new node is added on top of the current node. The node square changes to a node-on-node indicator .
To move a path
Back to Top
Edit tab
3 Drag any contour in the path.
To move a contour
Back to Top
Edit tab
3 Hold down Shift, and move the cursor over the contour until the cursor displays "SUB."
4 Drag the contour.
You can also move a contour by double-clicking a node to select all nodes, and then dragging one of the nodes.
To reverse a path or contour
Back to Top
Edit tab
3 Click on a contour or path.
4 Select a node.
If you want to reverse multiple contours, select one node from each contour.
5 Right-click the path or contour, choose Edit, and then choose one of the following:
• Reverse Path
• Reverse Contour
To duplicate a contour
Back to Top
Edit tab
3 Select one or more nodes.
4 Choose Objects Edit, and select one of the following options:
• Duplicate — copies the selected contour and pastes it directly on top of the original contour
• Duplicate & Offset — copies the selected contour and pastes it at an offset from the original contour. The default offset is 10 pixels in the X and Y directions.
You can adjust the offset from the original contour by adjusting the settings in the Duplication X and Duplication Y controls on the Tool Options palette.
To delete a contour
Back to Top
Edit tab
2 In the Tool Options palette, click the Edit Mode button .
3 Click on a contour.
4 Double-click one node to select all nodes.
5 Press Delete.
You cannot delete a path. A path is deleted with its object or when all of its contours are deleted.
