Editing shapes
You can edit the basic properties of vector objects, such as the line width, line style, and anti-aliasing. You can also rename an object in the Layers palette. You can also hide or display vector objects.
To modify vector object properties
Select the vector object you want to edit.
If you want to edit multiple objects, choose the
Pick tool
, hold down
Shift, and marquee select the objects.
On the Tool Options palette, click the
Properties button
The Vector Property dialog box appears.
Adjust any of the settings.
To edit a shape by using the Tool Options palette
On the Tools toolbar, select the
Pen tool
Edit Mode button
Click the shape you want to edit.
4
Adjust any of the available settings on the Tool Options palette.
Edit mode lets you edit shapes in a variety of ways; however, you can also edit shapes by using the Pick tool
to move, rotate, align, and stretch shapes.
