Setting Autosave preferences
The Autosave Settings window lets you specify Auto-Recover and Autosave options.
Edit tab: You can enable Auto-Recover to save temporary copies of all open files at specified intervals. If the application closes unexpectedly, the copies will be recovered the next time you open the application.
Adjust tab: If you have enabled the Adjust tab, PaintShop Pro lets you automatically save your work as you move between tasks. For example, if you make some edits from the Adjust tab, and switch to another photo or tab, your changes will be applied automatically.
It is recommended that you enable Auto-Preserve if you enable Autosave. For more information, see Setting Auto-Preserve preferences.
To set the autosave preferences
Back to Top
Edit tab
Manage tab
1 Choose File Preferences Autosave Settings.
The Autosave Settings dialog box appears.
2 Do any of the following:
• Click the Adjust tab and mark the Save edits to the current image automatically when the next image is selected check box.
• Click the Edit tab, mark the check box for Auto-Recover, and type or set a value in the minutes control.
3 Click OK.
To find out where PaintShop Pro saves the Auto-Recover files, choose File Preferences File Locations and select the Undo/Temporary Files folder from the File Type list.
