Scaling photos by using Smart Carver
Smart Carver lets you make a photo narrower, wider, shorter, or longer without distorting the content. By automatically detecting and removing zones in the picture that have little structural detail, this feature lets you change the aspect ratio without noticeably changing the image. You can also target a specific zone to remove from the photo, regardless of its level of detail, or preserve specific objects or image areas.
Smart Carver lets you selectively remove or protect areas when you scale an image.
To remove or preserve an object by using Smart Carver
Back to Top
Edit tab
1 Choose Image Smart Carver.
The Smart Carver dialog box opens.
2 To remove or preserve an object or area from a photo, do one or both of the following:
• Click the Remove button and apply the Remove brush to the areas of the photo that you want to remove.
• Click the Preserve button and apply the Preserve brush to the area of the photo that you want to protect.
In the Object Removal area, you can move the Brush Size slider to the left to decrease the size of the brush, or to the right to increase the size of the brush.
3 Scale the photo by applying one or more of the Smart Carving options.
You can also
Delete brushstrokes
Click the Eraser button , and apply it to the brushstrokes that you want to erase.
Zoom in or out
In the Zoom box, enter a magnification level, or use the slider or the arrows to adjust the zoom level.
Pan to view hidden areas of the photo
Click the Pan button , and drag in the preview area.
Hide the brushstrokes in the preview area
Mark the Hide Mask check box.
Reset the photo to its original state
Click Reset.
To scale a photo by using Smart Carver
Back to Top
Edit tab
2 In the Smart Carving area, perform one or more tasks from the following table, and click OK.
You can view the scaling results in the preview area.
To
Do the following
Set a photo width
Type or set a value in the Width box.
Note: The maximum width is double the width of the original photo.
Set a photo height
Type or set a value in the Height box.
Note: The maximum height is double the height of the original photo.
Reduce the photo width by 1-pixel increments
Click the Contract the image horizontally button until the image is the desired width.
Reduce the photo height by 1-pixel increments
Click the Contract the image vertically button until the image is the desired height.
Increase the photo width by 1-pixel increments
Click the Expand the image horizontally button until the image is the desired width.
Increase the photo height by 1-pixel increments
Click the Expand the image vertically button until the image is the desired height.
Reduce the photo width by automatically removing the areas to which you have applied the Remove brush
Click the Auto-contract horizontally button to remove red-painted areas.
Reduce the photo height by automatically removing the areas to which you have applied the Remove brush
Click the Auto-contract vertically button to remove red-painted areas.
