Working with nodes
Nodes are square points on line and curve objects. You can change the shape of a line or curve object by dragging one or more of its nodes.
Nodes have zero, one, or two control arms. The length and direction of the control arms determine the shape of the contour at the node. The straight or curved line between two nodes is a line segment. There are four types of nodes: symmetrical, asymmetrical, cusp, and smooth.
You can use symmetrical nodes to create smooth, flowing curves on either side of a node. Any adjustments to one control arm are mirrored by the other.
You can use asymmetrical nodes to obtain a different amount of curve on each side of the node, but keep a smooth flow through the node. You can adjust the length of each control arm, but the not the direction.
You can use cusp nodes to create extreme changes in direction. You can adjust the length and direction of each control arm independently.
You can use smooth nodes to create a smooth transition between straight and curved line segments.
You can select a node to edit, or you can move it. Moving a node alters the shape of a vector object. If an object has more than one contour, you can move all of its nodes. You can also move the path to move the entire object. You can edit the contour of a vector object by adding, merging, or deleting nodes anywhere along a path.
You can merge nodes on a contour while retaining the line segments on each side. The line segments are combined into one line segment between remaining nodes. If the contour is curved at the node, PaintShop Pro attempts to retain the curve.
You can also delete a node to remove the node and the line segments on each side.
To select a node
On the Tools toolbar, select the
Pen tool
On the Tool Options palette, click
Edit Mode button
The object's nodes appear.
The selected node appears with a solid gray fill.
Hold down Shift, and click the nodes.
Select all nodes on a contour
Double-click one node. If the object has only one contour, this selects all nodes in the path.
Select all nodes in a path (all nodes in the object)
Right-click a node, and choose Edit Select All.
Select the next or previous node on a contour
Hold down Shift, and press [ or ].
Hold down Shift, and click the node.
To view the selected node more easily, click the Visibility icon
on the Layers palette next to the vector object you are working on. This hides the fill and outline for the object. For more information about showing and hiding layers, see Viewing layers.
Start and end nodes are easy to find. The cursor displays "START" or "END" when you hold it over the node. If the shape is closed, the cursor displays "CLOSE."
To move a node
Pen tool
Edit Mode button
Select a node, and then drag it to a new position.
You can constrain a node’s line segments to 45-degree increments by holding down Shift as you drag.
To add a node on a contour
Pen tool
On the Tool Options palette, click one of the following buttons:
Edit Mode
Knife Mode
4
Hold down
Ctrl, and click where you want to add a node.
+ADD."
To add a new start or end node
Pen tool
On the Tool Options palette, click the
Drawing Lines and Polylines button
Select the start or end node of the contour.
4
Click to add another node.
The contour automatically connects to the new node.
To merge one or more nodes
Pen tool
Select the node you want to merge.
If you want to select multiple nodes, hold down
Shift and click.
Edit
Merge.
To transform nodes
Pen tool
Edit Mode button
Note: If you cannot see all of the options on the Tool Options palette, click the
More button
Select one or more nodes.
4
Choose
Objects
Transform Selected Nodes,
and choose one of the following commands:
Flip — moves selected nodes along the vertical axis (those on top go the bottom and vice versa). On a single node, the command flips the node’s control arms.
Mirror — moves selected nodes along the horizontal axis (those on the left go to the right and vice versa). On a single node, the command mirrors the node’s control arms.
Rotate — rotates the selected nodes by the current rotation setting. Applied to a single node, the control arms (if any) will rotate.
Skew X — moves selected nodes to the left or right (along the horizontal axis) using the current skew setting
Skew Y — moves selected nodes to the left or right (along the vertical axis) using the current skew setting
Contract — moves the selected nodes closer to each other by the current contraction setting. This command cannot be applied to a single node.
Expand — moves the selected nodes away from each other by the current expansion setting. This command cannot be applied to a single node.
5
Where applicable, type a value for the selected transformation setting.
6
Click the
Apply button
To adjust a curve using a node’s control arms
Select a node to display its control arms.
Note: Cusp nodes may have no control arms.
Move the cursor over a control handle until the cursor changes to two rotating arrows.
To constrain the control arms to fixed angles (45-degree increments), hold down Shift as you drag.
To straighten a curve between two nodes
Select two consecutive nodes.
Right-click one node, and then choose
Node Type
Convert to Line.
To delete a node
If you delete a node in the middle of an open contour, the vector object becomes two separate contours. If you delete a node in a closed contour, the contour opens.
