Graphics : Adding color clips
Adding color clips
Color clips are solid colored backgrounds. You can use the preset color clips or create new color clips in the Library. For example, you can insert a black color clip as background for end credits.
To select a color clip in the Color Library
1 Select Graphic from the Library Panel and choose Color from the Gallery drop-list.
2 Choose the desired color as displayed in the Library and drag to the Video or Overlay Track.
3 To add a color that is not in the Library, click the Add button beside the Gallery drop-list. In the New Color Clip dialog box, you can select a color either from Corel Color Picker or the Windows Color Picker.
Click the Options tab to set the Duration of the color clip in the Options Panel.
