Graphics : Adding color patterns
Color patterns are decorative backgrounds. You can use the preset color patterns or add an image that you want to use as a new color pattern in the Library. For example, you can insert a color pattern as a background for a title.
To select a pattern clip in the Color Patterns Library
1 Select Graphic from the Library panel and choose Color pattern from the Gallery drop-list.
2 Choose the desired pattern as displayed in the Library and drag to the Video or Overlay Track.
3 To add a pattern that is not in the Library, click the Add box beside the Gallery drop-list. In the Browse Graphics dialog box, choose the file that you want to add to the Library.
Click the Options tab to set the Duration of the color clip in the Options Panel.
