FastFlick : Adding music (FastFlick)
Most of the templates have built-in music that you can keep or replace. You can add your own music, delete music, and change the order of the audio files. You can also apply Audio Normalization to automatically adjust the volume of each music clip to the same level.
To add a background music
1 On the Add Your Media tab, click the Edit Music button .
2 Under Music Options, click Add Music.
The Add Music dialog box opens.
3 Select your audio files and click Open.
To rearrange audio clips
1 On the Add Your Media tab, click the Edit Music button.
2 Click an audio file in the Music Options list.
3 Click the Move up button or the Move down button to change the audio file order.
To delete an audio file
2 Click an audio file title and click the Delete button .
To apply Audio Normalization
2 Enable the Audio Normalization check box to adjust the volume of each music clip to the same level.
