Adding objects or frames
Add decorative objects or frames to your videos as Overlay clips.
To add an object or frame
1 Select Graphic from the Library panel and choose Object or Frame from the Gallery drop-list.
2 Select an object or frame from the Library and drag it onto the Overlay Track in the Timeline.
3 In the Player panel, adjust the size or position of the object or frame in the preview window.
If you want to apply additional changes, in the Options panel, choose the options you want from the Edit, Color, or Effect tabs.
