Workspace tour : Changing the application language
You can change the application language of VideoStudio.
Note: If the language does not display as expected after you make the change in VideoStudio, check the following in Windows:
Verify that the language you want to display is added in the Windows language settings (Windows Control Panel > Clock, Language, and Region > Add a language).
For non-Unicode text, change the system locale.
To change the display language
Click Settings > Display Language, and choose the language you want from the submenu.
