Convention
Description
Example
Menu >Menu command
A menu item followed by a menu command
Click Settings > Preferences > Edit.
drop-list
A list of options that drops down when a user clicks a down arrow button
Select a profile from the Profile drop-list.
A note containing information that is important to the preceding steps. It may describe conditions under which the procedure can be performed.
Enable Flatten audio and background video if your browser can only support a single track for audio and video.
A tip containing suggestions for performing the preceding steps. It may present alternatives to the steps, or other benefits and uses of the procedure.
For best results, use a tripod when you shoot photos and videos that you want to use in your stop motion animation project.
