Capture and import : Using DV Quick Scan
Using DV Quick Scan
Use this option to scan a DV device for scenes to import. You can add the date and time of your video.
For more information on this feature, see DV-to-DVD Wizard.
To add the date and time of your video
1 After scanning your DV tape, click Next.
This will then display the Import Settings dialog box.
2 Select Insert to Timeline and choose Add video date information as title.
Note: If you want the shooting date to appear for the duration of the video, select Entire video. If you only want a portion of the video, select Duration and specify the number of seconds.
