F3
Set mark-in
F4
Set mark-out
L
Play/Pause
Ctrl + P
Play/Pause
Space
Play/Pause
Shift + Play button
Play the currently selected clip
K
Return to the start of clip or project
Home
Ctrl + H
End
Move to the end segment or cue
Ctrl + E
End
D
Previous frame
F
Next frame
Ctrl + R
Repeat
Ctrl + L
System Volume
S
Split Video
Tab
Toggle between the Trim Handles and Scrubber.
Enter
When the left Trim Handle is active, pressing [Tab] or [Enter] switches to the right handle.
Left
If you pressed [Tab] or [Enter] to make the Trim Handles or Scrubber active, use the Left-arrow key to move to the previous frame.
Right
If you pressed [Tab] or [Enter] to make the Trim Handles or Scrubber active, use the Right-arrow key to move to the next frame.
ESC
If you pressed [Tab] or [Enter] to activate and toggle between the Trim Handles and Scrubber, you can press [Esc] to deactivate the Trim Handles / Scrubber.
