Save and share : Saving a track as an alpha channel video
Alpha channel video supports transparency, allowing you to save animated logos, lower-third graphics, and other objects and animations as video files that you can share and reuse as overlays in other video projects. For example, if you create a series of videos, you can overlay the start of each video with an animated title that identifies you or your company as the creator of the series.
To export a track as an alpha channel video
1 In the Share workspace, click the Computer button .
2 Click MOV.
3 From the Profile drop-list, choose one of the Alpha channel video profiles.
4 In the File name box, type a file name.
5 In the File location box, specify the location where you want to save the file.
6 Set any of the following options:
Create Preview Range Only — renders only the section of video that is selected between the Trim Markers in the Preview panel.
Enable Smart Render — analyzes a video for any previously rendered sections and renders only the new or revised sections. This can reduce rendering time significantly.
Enable Hardware Encoder Acceleration — can speed up processing by optimizing available hardware. Choose an option from the Type drop-list (see other settings in Preferences > Performance > Hardware acceleration).
7 In the Export Track drop-list, choose the track that you want to export.
8 Click Start.
The exported video preserves any transparent areas.
