Save and share : Creating sound files
VideoStudio lets you create a sound file from an existing video file. This is especially useful when you want to use the same soundtrack with another set of images, or when you want to convert the audio from a live performance into sound files. VideoStudio makes it easy for you to create an audio file of your project in M4A, OGG, WAV or WMA formats.
* To create an audio file
1 In the Share workspace, click the Computer button , and click Audio.
2 From the Format drop-list, select an audio file format.
If you want to adjust the settings for the format, click the Options button and adjust any of the settings on the Profile or Attributes pages.
3 In the File name box, type a file name.
4 In the File location box, specify the location where you want to save the file.
5 Set any of the following options:
Create Preview Range Only — renders only the section of video that is selected between the Trim Markers in the Player panel.
Enable Smart Render — analyzes a video for any previously rendered sections and renders only the new or revised sections. This can reduce rendering time significantly.
6 Click Start.
