Save and share : Saving to video files for computer playback
VideoStudio lets you save your movie project to video file formats that you can playback on computers.
Before rendering your entire project into a movie file, make sure you first save it as a VideoStudio project file (*.vsp) by clicking File > Save or Save As. This lets you return to your project at any time and make edits.
* To create a video file for computer playback
1 In the Share workspace, click the Computer button .
2 Click one of the following buttons to view and choose the profile for your video:
• AVI
• MPEG-2
• AVC/H.264
• MPEG-4
• WMV
• MOV
• Audio
• Custom
If you want to use the Project Settings for the video file, enable the Same as Project Settings check box located above the buttons.
3 In the Profile or Format drop-list, choose an option.
If you want to create a custom profile, click the Create Custom Profile button . For more information, see Working with custom profiles in the Share workspace.
4 In the File name box, type a file name.
5 In the File location box, specify the location where you want to save the file.
6 Set any of the following options:
• Create Preview Range Only — renders only the section of video that is selected between the Trim Markers in the Preview panel.
• Enable Smart Render — analyzes a video for any previously rendered sections and renders only the new or revised sections. This can reduce rendering time significantly.
7 Click Start.
Press the [Esc] key to cancel the rendering process.
A progress bar appears when you render a video. You can use the buttons on the progress bar to do the following:
• Click the Pause/Play button on the progress bar to pause and resume the rendering process.
• Click the playback button to enable the preview while rendering or stop the preview to reduce rendering time.
The rendering progress bar
