Adjusting tracking paths
You can fine-tune or modify the behavior of a tracking path by manually resetting track points. For more information on creating tracking paths, see Tracking motion of video objects.
* To adjust tracking paths
1 Select a video file on the Video Track and click the Track Motion button on the Toolbar.
2 From the list of trackers, select the tracker that you want to adjust.
3 Drag the Scrubber to locate the point where you want to adjust the path.
4 Drag the tracker to the new key frame position.
5 Click the Track Motion button to retrack the path. The tracker continues tracking using the new key frame position.
Adjusting the track points allows you to fine-tune or smoothen the movement of matched objects.
* To define the tracking path duration
1 Drag the Scrubber to the point where you want to start motion tracking. Click the Track in button .
2 Drag the Scrubber to the point where you want to end motion tracking. Click the Track out button .
The tracking path duration is defined.
* To extend tracking path duration
1 Drag the Scrubber to the untracked area where you want to end motion tracking.
2 Click the Track Motion button .
The motion of the tracked object and the extended path are generated.
Dragging the Scrubber and clicking the Track in button removes the current path and marks a new starting point.
* To reset tracking paths
You can reset the current tracking path and select a new area to track by doing any of the following:
Drag the tracker point to another location.
Drag the Scrubber to another location and click the Track in button .
Click the Reset button .
* To show or hide trackers
Click or to show or hide trackers.
* To add trackers
1 Click the Add a new tracker button to add the second tracker. A new tracker appears on the screen and a new tracker is added to the list.
2 Drag the tracker to the part of the video that you want to track.
In our example, the second tracker is dragged to a stationary fishing ladder on the lake.
3 Click the Track Motion button .
If Show tracking path is selected, the paths of both trackers are displayed and the selected tracker is highlighted.
In the example, Tracker 1 tracks the boy while Tracker 2 tracks the stationary fishing ladder on the lake. Since the camera is panning to the right, the result shows the path of Tracker 1 moving to the right and the path of Tracker 2 moving to the left.
4 Click OK.
To remove a tracker, select a tracker and click the Remove tracker button .
* To rename trackers
1 Select a tracker and click the Rename tracker button .
2 Enter the new tracker name in the Rename Tracker dialog box.
3 Click OK.
