Changing the application language
You can change the application language of VideoStudio.
Note: If the language does not display as expected after you make the change in VideoStudio, check the following in Windows:
• Verify that the language you want to display is added in the Windows language settings (Windows Control Panel > Clock, Language, and Region > Add a language).
To change the display language
• Click Settings > Display Language, and choose the language you want from the submenu.
